Beam Structural family.
Darwin33
Darwin33
I have a steel beam family SQ 120 square section (120X120).
Inside this family I have added as an extrusion a plate 15 mm in the perimeter.
My problem is that when I load the family I can not see the plate, only the beam. Could be because this beams are connected?
azad.Nanva
post your beam here or post this part of structure.
jay_colc
No it would not hide because they are joined it should give an error or warning otherwise with the join?
Really I would model them separately unless this will be fabricated this way
Jay Colcombe
Autodesk Certified Instructor
