Beam and Wall Intersection
Tania-MTD
Tania-MTD
Community Visitor
Community Visitor
I have ceiling beams drawn via Structural > Beam System.  How can I get the intersecting line to show where the base of the beam and the wall touch?
I tried to join the geometry, but Revit won't allow the elements to be joined.
ctm_mka
First, when you say "Revit wont allot the elements to be joined", is it throwing any sort of message? or is it not allowing you to select the beams, because they are technically joined already? Second, try removing the beam system and drag/dropping the end point back on to the wall (may need to re input elevation), sometimes that refreshes things.
Tania-MTD
Community Visitor
Community Visitor
Yes, that's correct.  I am not able to select the beam(s).
