Batch add shared parameters
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
Does anyone know a good way to batch add shared parameters?
Adding each parameter one by one is tiresome for larger projects with many files, usually done for sheets and their parameters.
Rushforth Tools
Viveka_CD
Thank you, @barthbradley RF tools is a great add-in I've used personally for projects. See demo below:
@Marcus.Isacsson HERE is another post with batch add-in recommendations by @Alaaeldin_Alsahli
If you find posts have solved your problem, please click on 'Accept as solution' button below to help others with similar questions.
