- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
How can I get a basketball goal post as a library component?
@jmmeshack2HNET hello, you can refer to this LINK. thanks
Find or create your own family file. Find the folders on your computer that contain your family libraries. Save the file into those folders somewhere.
Try BIM Object or ARCAT websites. If not, run a search for sporting equipment. Find a family that is close to what you want. It doesn't have to be perfectly identical to what you need - just enough information to make it read correctly on your plan drawings would do.
Families that are too detailed and complex would create problems for the model. FYI.
Is this something that will be used frequently? Then I would save the family to the centralized library. If it's something that will not be used very often, then I would save it to a folder that contains project-specific materials.
I see that you are a new visitor. Welcome to the Autodesk community! ![]()
Please see Draperinc for basketball goal post downloads. You will find CAD dwg and specifications
Also, do a search for basketball or athletic equipment on CAD details
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Did you achieve what you were looking for regarding outdoor basketball goal post? I am looking for the same thing.
