Message 1 of 10
10:21 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Revit noob here,
After searching the internet and not finding a solution I have decided to post here. I have materials in my model and they are showing fine, apart from the walls. There is a texture attached to the weatherboard material and, I also tried it with the roof texture to make sure it wasn't a problem with the image, but that didn't work either. Tried moving the layers around and changing different settings in the assembly menu.
Thank you for your help.
Oli
