Base extension distance causes wall joins to malfunction
tom-common
tom-common
I am sure this must have been raised before as it seems like such a common occurrence.  However:
Can someone explain how to stop this happening?
I have unlocked the external layer of the wall so that I can raise it above DPC level, see below:
However, when perpendicular walls meet which have this feature they do not join properly (not if the Base Extension Distance is the same for both walls), see below:
Results in this in plan view:
If you change the base extension, so that each wall has a different value, you get this:
i.e. correct joining.
Unfortunately, in elevation you end up with this sort of thing happening:
I have tried changing the material priorities within the wall, but it doesn't seem to make any difference.
Any help would be greatly appreciated.
Thanks.
vitorbortoncello
I suggest creating parts or modelling each layer individually for more control
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Are you talking about this:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Base-Extension-Dis...
BTW: We model walls with base extensions in every project. We have no issues.
tom-common
@barthbradley - YES, exactly that - thanks.
SteveKStafford
If find changing the wall join to Miter allows walls of this sort to cleanup better.
Steve Stafford
