Baluster Spacing Help
michael88TDQ
michael88TDQ
I am planning out a railing to be applied to stairs/floors. I am currently trying to space it and honestly I feel that I have the spacing exactly right but something foundational is obviously not working here and I am at a loss. Basically, there should be evenly spaced post-like balusters, and in-between those there is a metal grate panel. However, some of these elements are not showing up. One thing I would like to avoid if possible is balusters overlapping with the start and end posts. I am unable to share the file due to NDA, but in general this should be a simple panel/post railing. Although it clearly is not that simple lol.
Mike.FORM
You can see the post that is part of your pattern is clashing with the end post.
Change the distance from previous for your post in the pattern to 0".
