Bad image
Bad image
Message 1 of 12
Bad image
I am new to Revit and when I opened one of the files for training this is what my screen looks like See Attached.
Can someone help?
Replies (11)
Message 2 of 12
constantin.stroescu
Try to uncheck Hardware Acceleration:
Application Menu (R) > Options> Graphics>Graphics Mode > Uncheck : Use Hardware Acceleration
Constantin Stroescu
Message 3 of 12
I have done that but it makes no difference.
Message 4 of 12
constantin.stroescu
try to make another 3d View and see if the error persists......maybe this is a distortioned perspective or you have CAD links attached...from VGO uncheck imported categories...
Constantin Stroescu
Message 5 of 12
Do you think it can be a Graphics Card problem, I have a Nvidia Geforce 7800 GT card.
I have used the model supplied with my Revit 2017LT program and it gives the same problem. See Attached.
Alan
Message 6 of 12
constantin.stroescu
Message 7 of 12
I think that the link from the previous post was erroneous....
Here is it again:
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Constantin Stroescu
Message 8 of 12
That card should be replaced with a newer card, as it is over 10 years old...  Make me wonder what your other system specs are.
Message 9 of 12
I am replacing the card with GT630 2GB GDDR5 2048MB Video Graphics Card WIN10 HDMI PCI-E
My system is a 2 year old i5 64 bit 16 Gb Windows 10.
I think this should be OK.
The reason I still had the old graphics card is because it worked fine and as I am not a gamer I did not see the necessity of replacing it.
However now with Revit it looks like I need to replace it.
Message 10 of 12
I would not recommend a GT anything for Revit.   Spend a little and get a decent 7xx or above GTX.  Value cards like the GT's are just going to give you the same issues as you are currently having.  You don't have to be a gamer to get a GTX.  If you want to do rendering and walkthroughs in Revizto and Lumion, you will need a pretty recent GTX card too.
Message 11 of 12
Thanks for your advise, but could you tell me what type of card is a decent 7xx
Message 12 of 12
Thankyou everyone that tried to help with the bad image that I was getting in revit. I replaced my old Geforce 7800 graphics card with a GT630 2048Mb card and my image is perfect.
Thanks once again.
