Backwards casework family preview in Properties
Sahay_R
Mentor Mentor
Message 1 of 21
Sahay_R
I have just finished developing a whole bunch of casework families. Now when I insert them into a test Project, the preview in the Properties dialog is BACKWARDS!
I have already -
1) clicked SaveAs and changed the preview thumbnail
2) clicked the View Cube to set the desired view as the Home view
3) clicked the View Cube to set my thumbnail view to front
AND THE PREVIEW STILL LOOKS THE SAME!!!
However - get this - in the Recent Files - the preview looks beautiful. Go figure.
I saw a thread in this regards that started in 2010. Don't get me wrong - I love Revit, I really do - but when it makes my lovely work look bad (yes, ALL of my new Casework families have backwards previews) I am NOT happy!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (20)
Message 2 of 21
chrisplyler
Totally guessing here...
Maybe the preview doesn't get refreshed every time you "Load to Project" again?
What happens if you totally purge the family from the project file and load it anew?
Message 3 of 21
FAIR59
if there are no "model" changes on reload, Revit will not reload the family (and doesn't tell you either). Solution: for a random parameter type in the same value, and this will count as model change.
Message 4 of 21
Sahay_R
@chrisplyler Purged. Reloaded. No go.
@FAIR59 - will try that when I get back into work!
Rina Sahay
Message 5 of 21
Corsten.Au
Will this help? while saving, tick for " Regenerate view / sheets "
Cheers!
Corsten
Building Designer
Message 6 of 21
Isn't is a known issue? Maybe the template was created by Kevin Spacey?
Message 7 of 21
Alfredo_Medina
This is another issue that has been known for years, but it doesn't get fixed.
I see an email coming soon saying that we should submit this as an idea. Smiley Wink
Message 8 of 21
Sahay_R
@Alfredo_Medina says idea, @Alfredo_Medina gets an idea.
Vote here -
https://forums.autodesk.com/t5/revit-ideas/backwards-casework-family-preview-in-properties/idi-p/752...
Rina Sahay
Message 9 of 21
Sahay_R
@FAIR59 - tried that too, no go.
Smiley Frustrated
Rina Sahay
Message 10 of 21
chrisplyler
Okay, so what happens when you rotate all the geometry around 180-deg right in the family?
Message 11 of 21
Sahay_R
@chrisplyler Did it. Also told the view cube that Front is Back. Set it as Home View. No go. Preview in folder looks awesome. Preview in Properties looks aweless. Ripping my hair out here.
Rina Sahay
Message 12 of 21
Why waste thy energy over a known issue?
Message 13 of 21
Sahay_R
....or mine hair.
Very true. Leaving the hair alone as I type....
Rina Sahay
Message 14 of 21
Sahay_R
The only thing that I have found that works for me is to flip the geometry in the family so that Front points Up.
For longer lasting results - create a custom Casework template. Open the OOTB Casework template,  flip the reference planes so that Front points Up, save as a family, and then change the extension from RFA to RFT.
Rina Sahay
Message 15 of 21
antonjubani
Dear Autodesk how is this issue solved?
So you suggest that solution is to model families backwards so that they appear correctly in the family type browser??
That is certainly not the right solution.
Please fix the template or tell us a workaround until this is done.
Message 16 of 21
Sahay_R
See the second part of the solution. Create a custom template.
Rina Sahay
Message 17 of 21
ca
Observer
Observer
Hi.
Is this still not fixed "Backwards casework family preview in Properties"
Message 18 of 21
ca
Observer
Observer
Hi.
Message 19 of 21
wilhelm.schnell
Observer
Observer
Hallo, das ist sowas von nervig, und die vorgeschlagene Lösung ist inakzeptabel. Seit Jahren wird die Vorschau falsch dargestellt, obwohl man die Familie mit der Vorschau richtig anzeigt
Message 20 of 21
James_Reben
Working in Revit 2024 and it is still not fixed, at least for the default base cabinets, ugh.
