Background Color Scheme not loading one pattern
bmyrumYGWJ2
Message 1 of 9
bmyrumYGWJ2
Every user on this cloud-shared project's finish plan looks like the attached. For some reason color type CON2 and any new ones we create only load as pink diagonal crosshatches. Every other floor-type finish worked fine until we added this one.
Replies (8)
Message 2 of 9
Message 3 of 9
bmyrumYGWJ2
The problem is that no matter what we put there it looks like the pink diagonal cross hatch.
Message 4 of 9
Okay, if I understand correctly, no matter what color and pattern is assigned in the Color Scheme Dialog Box, the color and pattern remains the same - pink and crosshatch?  If so, that's bazaar. I'd open a support ticket on it myself.
Message 5 of 9
TripleM-Dev.net
Hi @bmyrumYGWJ2,
Workshared model?, if so create a new Local, and clean out the windows temp.
And / or audit central file itself.
- Michel
Message 6 of 9
bmyrumYGWJ2
it is a cloud-shared model.
Message 7 of 9
TripleM-Dev.net
Then clean the CollaborationCache on the local machine, this will re-create the local.
I think this is still it's location? https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Collaboration-for-...
I had a this exact thing a week or so ago, a colleague, couldn't update the colorfill with new values.
If I opened the model the values updated directly and after a sync he could see them also. It was a rather old local, told him to create a new one, clear windows temp, and issue was solved after that.
Message 8 of 9
azad.Nanva
Do you Check the filters?
Message 9 of 9
bmyrumYGWJ2
it turns out to be a memory issue. once the computer was fully restarted and the file audited it printed correctly.
