Background color drafting view
I have a problem in my template, when I create a new drafting view the background color is always beige and not white. With the default Autodesk template, it's white. Do you now how to change this (I join the template) ?
Thanks a lot, Smiley Wink
porterja
Hi fafa007,
Thank you for contributing to the Autodesk community. It is always a tremendous help to make as much knowledge as possible available for everyone to find.
I understand you are looking for instructions on how to change the background color in Revit.
Here are some helpful links explaining how to adjust different color options:
Please feel free to let me know if you need anything else and I will be more than happy to help.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Jarrett Porter
Technical Support Specialist
porterja
Good Morning fafa007,
I hope all is well. Just wanted to follow up with you to see if the information I provided helped answer your question. Please feel free to let me know if you need further assistance and I'll be glad to help.
If my post answers your question, it would be helpful to click the "Accept as Solution" button since this allows everyone to find answers more quickly.
Jarrett Porter
I discovered the problem. There was on the drafting view an elevation drawing template that had a background. The drawing view takes on the color of the soil.
Some kind of bug?
I saved the template in the attached file.
Thanks for your help.
sathishkumar.muthumanickamGVRJN
Observer
Observer
May i know how did you make the grey color hatch, can i make it that grey in 3D view alone? if yes, please share the procedure step by step.
Thanks in advance for your prompt response.
