I would like to know how to avoid seeing seam lines between each panel on a curved form wall. I want the wall to look smooth with opening and I don't want to see the seams between each panel. I have identified the issue on the photo attached.
My process in the attached file: (I have used Twinmotion to render this)
- Using "Spline" I created the geometry
- Divided the surface
- Choose rectangle 2550mmx250mm
- I then created the panel in the "Model Pattern Based"
When I applied the panel to the geometry, the seam between each panel is visible. Can you please tell me how to fix this issue.
Thanks.
Morteza
Solved by ToanDN. Go to Solution.
Thanks for the reply.
I just tried that, but then I placed a perforated pattern using voids in "model face-based". The pattern is all stretched due to the curved wall. See attached screenshot. Any tips?
Morteza
Are you talking about the edges of the rectangle 2550mmx250mm panels? Use the Linework Tool (Modify Tab) to make them invisible.
...if you are seeing the edge as blue lines, edit Divided Surface and untick Surface/Pattern.
