Hi everyone,
I’m working on creating custom parameters for my Revit families/elements, and I want one parameter’s value to be automatically filled based on the value of another parameter. In ArchiCAD, there is an “expression” feature that allows you to copy the value of one parameter and assign it to another, so you don’t have to manually enter the same data multiple times.
Is there a similar way in Revit to link parameters so that when the original parameter changes, the custom parameter updates automatically? For example, if I have a built-in parameter like “Length,” can I create a custom shared parameter that automatically copies that length value without me typing it in again?
I’m looking for a method within Revit families or element parameters that lets me set up this kind of automatic parameter syncing or formula. Any suggestions or best practices for achieving this would be greatly appreciated!
Thanks in advance!
