We have a shell office building and are also doing the finish out for one of the tenant spaces. The tenant model was linked into the shell model but the tenant linked model was set to be non-Room Bounding (the default, under Type Properties of linked file). We noticed that despite not being a room bounding model the walls and room separation lines in the linked file we bounding the rooms in the shell model. Troubleshooting so far:
Really at a loss here. The tenant model is a single-story, very basic model. Nothing above or below that could be creating the phantom boundaries. I have no idea how these phantom boundaries could be affecting the shell model when the models are not even linked together.
You've got company. A couple of months ago there was a post describing the same thing. No solution to date. We jumped through all the hoops on that one. Maybe it's a "bug". Is it possible for you to post the file, instead of going back and forth with guesses?
I was trying to find a way to post the file without identifying information due to my firm's privacy policy. I detached the tenant model and was preparing to post it on its own; however, without the shell model loaded in, I cannot recreate the error. In the tenant model alone, with no linked models the room boundaries behave normally. Once I linked in the shell model the original phantom boundaries returned. Again these boundaries do not exist in the shell model only in the tenant model. I will keep trying to figure out a way to post both files but I need to clean up identifying information that could create a privacy concern.
I found these information contradicting:
- from your 1st post: Completely removed the linked file from the shell model. Synced, closed and reopened the file. The rooms in the shell model are still being bounded by the tenant model which is no longer linked or loaded into the shell.
- from your 2nd post: I detached the tenant model and was preparing to post it on its own; however, without the shell model loaded in, I cannot recreate the error.
Yes it is very confusing to describe.
1st Post
When I have the shell model open and the tenant model is not linked the error still occurs. I get phantom room boundaries as if it were still loaded.
When I open the tenant model with the shell loaded I have phantom room boundaries which remain even when walls are deleted or moved.
2nd Post
When I open the tenant model WITHOUT the shell loaded room boundaries act as normal in the tenant model. As soon as the shell model is linked in the error reappears and the phantom boundaries return.
It seems like the error only happens in one direction. When the shell is unlinked from the tenant model I get normal behavior. When the tenant model is unlinked from the shell the error still occurs.
Hope that's clear?
Phasing
Both models and views are in the new construction phase and set to show 'Previous+New'
The shell model has an existing phase that contains existing building elements which are being demo'd.
The tenant model has a 'blank' existing phase that contains no elements. All of the phantom boundaries are from the 'New Construction' phase.
Without a model in hand and from how it looks like, that's a phasing /phase filter issue...
Had a similar problem.
What I did was create a new phase, named it New Construction 2, drew some walls off to the side (something needs to exist on a phase before it can be merged) and then merged the original New Construction phase into my created New Construction 2 phase. This worked for me at least.
Hi, We have the same problem in Revit 2022. We have deleted some walls from our model but they are still acting as room bounding elements.
Does anyone know if there are any fixes available yet?
