Automatic Scale Revit Views Based on Title Block
theresatlninhMWWN4
theresatlninhMWWN4
Is there a way to automatically scaling views, that is already set up on title block, to change scale and fit in title block when changing title block from 24x36 to 11x17 or Vice versa?
RSomppi
You could use print to fit page.
I that doesn't work for you then to answer your question, no. You will need additional views for each sheet size.
