Automatic creation of the infilling wall by a door
Can someone help me?
I have 2 different families. Both own creations. I put these doors in an existing wall and both doors are in phase new. Somehowe the single door gets a phase error but made an opening in the existing wall. The double door has no error, but made no opening and views the opening as a wall that has to be demolished. Because the are both on the same phase in the same wall, i guess it has to be something in the families.
images attached
Thanks in advance
hmunsell
can you upload the the model and/or the Door family?
Howard Munsell
Yes,
I just made a little project for it so it's easier to see te difference.
I'm from Belgium, so things will not be in English except for the phases that i changed.
Make the Void Cut deeper in the Door Family.
Change the view's phase filter to Show Previous + New or Show Complete.
FAIR59
In the binnendeur_enkel - family, the problem element is the void for the tussendorpel. It is also cutting the wall, is this intentional ?
Uncut the void from the wall and the problem is solved.
OK, that's it! There is indeed one void to much. It's a left over from the past when whe needed an extra option to cut a floor when we have a sill (tussendorpel). The second one has to cut a wall underneath. And when i'm not mistaken, I can do it all with one void. Thank you very much!
