Autodesk Viewer
Autodesk Viewer
Autodesk Viewer
I'm trying to upload Revit files on Autodesk Viewer so contractor can use the dimension tool out it the field. However the architect has each discipline saved as a separate file and has them overlaid. When I upload the mechanical file it doesn't show any of the walls that were drawn in the architectural file. I am wondering if there is a way to have the two files loaded together on Autodesk viewer.  The arciterural plan is the parent file and when i upload that it only shows the architectural sheets but has all the MEP systems in 3D view but wont upload the sheet views for the MEP files.
To view the model as a whole you need to bind the links and upload the bound result file. To view the Sheets you need to upload the original files where the Sheets were created. For sheets, it's better share a DWFs with all sheets of all disciplines combined.
That is how it is supposed to work.  If you want the MEP sheets open the MEP model.  Linking the MEP sheets into the architectural model is a waste of time and money.
