Autodesk Viewer show 3D only?
H, I am new to the free online tool Autodesk Viewer. I found it's a good tool to communicate with people who don't have a Revit, but there is a problem to me. Is there any way I can only share the 3D view to someone not the sheets through Autodesk Viewer? The model is in a progress phase, so it's a mess on the sheets and I don't want incur questions or misunderstanding from the people whom I share the revit model to. Any advise or solution? Thanks.
constantin.stroescu
Try these :
  • in Project File: Collaborate >Publish Settings>Make a Set that contain only the 3d View > Save and Close.
  • Save the File
  • Load the saved File in the Viewer
Constantin Stroescu
ennujozlagam
you can try this
1. go to 3d view
2. go to file
3. export
4. dwf / dwfx
5. export :current view/sheet only
6. next
7. saveas as DWF
8. select your folder
