Autodesk Viewer Decal/Material Issue
I'm trying to upload a revit file to Autodesk viewer that has some decals used for signage.
None of these show up, the area is just shown as a green rectangle with a cross.
After some searching I found the below threads and now understand this is not possible but custom materials do work.
https://www.reddit.com/r/Revit/comments/afcf09/is_it_possible_to_make_decals_from_revit_visible/
I have managed to setup a custom material using the signs/artwork and have a couple of issues.
I can set the image to match the size of the split face boundary but then it is off centre, if I don't have it set to tile nothing shows. So I leave it on tile and keep changing the offset until it looks right. I then upload it to Autodesk viewer and it is in a completely different position.
I have tried resizing the image to match the size using gimp and have tried having it smaller and scaling it in Revit. Neither seem to look right.
Is there something I am missing or is this some sort of bug?
screenshot1 is in Revit and screenshot2 is Autodesk Viewer.
