I ‘ve been trying to sign-in into Revit app. for days but it is always the same thing. It keeps the Autodesk logo going around and around and around until stops after several minutes. Then closes. I go to my account and everything looks right. So I don’t understand what do I have to do to get sign – in?
Thanks.
Solved by aRcHiTeCt.JM. Go to Solution.
…. hi @Anonymous
… are you connected to internet ?
… are you using a firewall ?
… if so .... allow all autodesk connections to go through your firewall
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
