Autodesk Raytracer- How to remove default green ground
Hi! The default bright green ground color is ruining every render. How can I change it to a more neutral white or gray? Background->Style is set to Sky rather than color or image.....Thanks!!
constantin.stroescu
?!.....but you have here the option for ground color...
Constantin Stroescu
L.Maas
Do you have a toposurface (or other object) with for example grass material in your model?
If so remove that object or change material
Louis
Please mention Revit version, especially when uploading Revit files.
Hi, thank you for the suggestions. I do not have a toposurface in the model, but I do think that it is the background option that I need to change. For some reason my dialog does not give me this option, and I cannot find a way to turn this option on (see screenshot). Any idea why it is missing or where to find it elsewhere?
Solved! The "photographic exposure" option in the dialog must be selected in order for the background color option list to appear. Otherwise it is invisible.
