09:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am testing the DWG Premium export plugin for Revit, which should significantly improve the quality of the DWG export from Revit.
However, I notice a Revit crash when I want to adjust the Layer General Mappings. To be more precise, Revit mill for very long minutes (I stop the software so much it's long) when I set these famous matches.
Do you have the same problem?
If so, have you managed to fix it?
Thank you in advance.
