Autodesk Desktop App not showing latest Revit 2017.2.4 update
jledgewood409
Message 1 of 16
jledgewood409
following a few revit blogs i have found out that there is a new Revit Update for revit 2017 (revit 2017.2.4). unfortunatly this update is not showing the Autodesk Desktop App for anyone in my office. wondering if Autodesk has found this to be true for others? if so, is there a resolution?
Replies (15)
Message 2 of 16
Try logging out and logging back in...it also has to be authorized to users to be downloadable at the account portal to show on the Desktop App.
But I show the 17.2.4 and 18.3.2 updates as of a week ago.
Message 3 of 16
jledgewood409
I logged out and logged back in and same result. everyone in our office has had that authorization for as long as I can remember.
Message 4 of 16
ennujozlagam
hello, try to uninstall Autodesk Desktop App and reinstall again, it could solve your issue. thanks
Message 5 of 16
jledgewood409
I tried that as well and no change.
Message 6 of 16
Viveka_CD
Hi @jledgewood409
Can you check for this update by signing in to your Autodesk Account at manage.autodesk.com and let me know if you are able to see this?
Message 7 of 16
jledgewood409
Yes, I do see the .2.4 update in that location. we typically get these updates from the Autodesk desktop app. just wondering why its not listed in the Autodesk Desktop App?
Message 8 of 16
Viveka_CD
Message 9 of 16
jledgewood409
I have done that with no success
Message 10 of 16
Viveka_CD
Hi @jledgewood409
I checked your account information.
You do have access to Revit 2017.2.4, if you've already installed this from your accounts portal, then this will not show up on your Desktop App.
Message 11 of 16
jledgewood409
for future use how do I make it so that I do have access to these updates?
Message 12 of 16
Viveka_CD
Hi @jledgewood409
The updates will show up when you have not installed them on both accounts portal and desktop app.
Message 13 of 16
jledgewood409
a similar situation is happening to a co-worker. this co-worker does not have revit update 2017.2.4 install and yet he is not able to see the update in his Autodesk Desktop App.
Message 14 of 16
Viveka_CD
@jledgewood409
Ask him to Launch Revit - sign out and sign in again to Desktop app. Make sure your co-worker is having the latest updates for your Desktop App.
Message 15 of 16
jledgewood409
this co-worker has done the step you recommended and no luck
Message 16 of 16
Viveka_CD
Hi @jledgewood409
Can you ask your co-worker to contact support?
This may be a subscription issue.
