AutoCAD file not showing up in REVIT
Message 1 of 16
I have been trying to link the autocad file to Revit and I have checked all the necessary steps but its showing in 3D view only. It doesn't appear in any other views. Please suggest something.
Prattusha.
Replies (15)
Message 2 of 16
ennujozlagam
hello, if youre going to link cad into revit you must consider current view only, positioning and place at. if you cannot see your link cad you have to go to visibility graphics > tick imported categories.
 And go to your autocad drawing move insertion points to 0,0 before linking to autocad. thanks
Message 3 of 16
Try relink it Center to Center.  If you want the CAD file to be 2D only, meaning only appear in the View you link it in, then check the box Visible in current View only.
Message 4 of 16
Hello @Anonymous
Click the box on Imported Categories to show all the imported categories in the particular view.
Message 5 of 16
Viveka_CD
Hi @Anonymous
Check "Show crop region" and "Crop view", the CAD file may be outside the crop region.
  • It could also be  due to the fact that the import object has been drawn at a large distance from its origin
  • Revit places the import’s world origin at the Revit project’s internal origin. This may cause the link to display at a large distance from the model. To test this, set the zoom to Zoom View to Fit.
  • Auto - Origin to Origin is the default positioning when you insert a Revit model or CAD file. As suggested by @ToanDN try center to center.
Note: If you change the default, the option you select for Positioning becomes the default for the current Revit session. The software remembers one default option for Revit models and another default option for CAD files.
Also, can you send us a screenshot of your view range settings?
Message 6 of 16
Karol_Piroska
one more note based on experience. Sometimes Revit does not set correct units of the linked cad file and this will end up being tiny, hidden under modeled elements. So another solution is center to center, current view only and set units manually.
Message 7 of 16
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
Message 8 of 16
Sahay_R
Also - check VG or View Template, as the case may be.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 9 of 16
Thank you all for your comments. I tried everything really...but nothing worked. May be the autoCAD file has some issues, may be the XREF's or some constraint. I will have to go back and check the Auto CAD file. But thank you all.
Message 10 of 16
Share the files.
Message 11 of 16
ennujozlagam
@Anonymous hello, it could be your autocad has issues. try to audit, purge, overkill, clean as much posiible. if there are xref's attched try to bind and try to link again using manual base point and see if helps. thanks
Message 12 of 16
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue? Were you able to test the AutoCAD file?
HERE is an interesting article on how to optimize your dwg file.
Let us know if you need more assistance from the community. As mentioned before we will be happy to test your file. Let us know if you can share the file - I can send you a private folder if you'd like.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Kudos welcome!
Message 13 of 16
Hello All,
It took me a while to come back to this post. My apologies. I checked that the files were done in sketchup and then the file assigned as .3ds. When I converted into AutoCAD, I have lost all the properties of it. Is it possible to import 3ds file in REVIT.
For this particular file, I went to Mangae->Object style->Imported Objects but then there is no layer or anything attached to it.
Please see the screengrab for it.
Please find the 3ds file and the autocad file attached here.
Message 14 of 16
Corsten.Au
Hi..
Try to give some material to 3ds file else its tough to get them showing on plan, elevation etc..
I have attached revit and cad file fixing the issue you faced..
Cheers!
Corsten
Building Designer
Message 15 of 16
Hello Ganesh,
The file was done in sketchup and was saved as 3ds. They have specified the materials in the sketchup file. I was able to open the file in REVIT but the characteristics were missing.
I tried to open the sketchup file but it's showing error.
Prattusha.
Message 16 of 16
Materials assigned in a SketchUp file won't come in Revit.  Use layers to separate different materials then use Object styles - Imported Objects to assign materials in Revit.
