Attaching wall to a roof problem
Mohamed_Faramawy
Mohamed_Faramawy
i am trying to attach this wall to this roof but that happens ? do anyone have an idea why ? Capture.JPG
dzanta
select wall, detach first...
then try reattaching again
if that does not work....
double click wall to edit profile and draw magenta lines for outline of wall based on roof.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
The wall must be completely within the roof boundary.  If your roof has overhang then the overhang may cover the wall but the actual boundary may not.  Check that.
chrisplyler
Possibly each half of that "roof" is really a separate Roof element, and when attaching the wall to it you clicked on the left side?
Mohamed_Faramawy
i am attaching the file for u all to check it
Make the wall shorter (horizontally) and it will work.
Mohamed_Faramawy
Yes, you are right. thanks a lot
