Hello everyone, please help me if there's something I'm not getting right. When placing a view on a sheet the Sheet's "Scale" parameter gets the value of the View's "Scale" parameter. Is there a way to create similar associations? e.x. the Sheet's "Sheet Series" parameter get the value of the View's "View Category" parameter
Solved by RDAOU. Go to Solution.
No not with an OOTB solution. The View Scale is an OOTB parameter.
Sheet Series and Sheet category are user defined => any solution would need to be user improvised (using Dynamo or an Addin)
What if you have Views of different View categories placed on one Sheet?
