Assign shortcut to "Switch window"
10x3x30r
10x3x30r
Can you assign a shortcut to the "Switch window" button?
ralphdenhaan
That is not possible, but you can use CTRL + TAB button to switch quickly.
(CTRL + SHIFT + TAB = reverse)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
handjonathan
Hi @10x3x30r
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @ralphdenhaan helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
10x3x30r
Thanks, no, this isn't helpful at all.
I will try to script something myself in C# to switch windows in a custom dialog. I assume that you know that this is a common feature in IDEs these days, so it shouldn't be hard (once I dig through all the boilerplate).
SteveKStafford
Switch Windows is ribbon custom drop down list box so what is supposed to happen with a keyboard shortcut? It doesn't have a separate dialog to open unless there are more views than the drop down will display. There is no shortcut for that Select View dialog either.
Personally I put the QAT under the ribbon and use Switch Windows from there so I never have to activate the View Ribbon tab to use it all.
Steve Stafford
10x3x30r
1. press shortcut
2. window pops up
3. navigate with arrow keys to your chosen window
4. bonus point if you can fuzzy search
SteveKStafford
Sounds like you should post over in the Ideas forum, maybe others will like it.
Steve Stafford
