Assign letters instead of numbers for views
vship
vship
Is there a way to customize the automatic numbering routine in Revit (for views) so it can auto-increment letters instead of numbers when you place these on a sheet? I know it does this for column grids, but I'd like to have this work if I place a view on a sheet, change the number to a letter, and have the next view assigned as the next number alphabetically.  It does work that way for door numbering.
mphungDCHNW
You can sort/ Rename the corresponding views in PB and it should sort them out when their in your level view.
