Assign global parameter to elements inside group
pfiala-ebmprague.cz
Message 1 of 9
pfiala-ebmprague.cz
i can't still assign global parameter to project parameter(set as different value in each group) to elements inside group.
Still is showing warning for ungroup.
any help?
Replies (8)
Message 2 of 9
kadmonkee
set 2 different groups then 2 different global parameters in each group
a single global parameter cant have different values
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 9
pfiala-ebmprague.cz
thx but my question is: I need add this global parameter to elements inside group(without edit group)
It is not possible..
Message 4 of 9
kadmonkee
correct it would have to happen in group edit mode then each copy of that group would comply with the global parameter
thank you
Message 5 of 9
pfiala-ebmprague.cz
I don't need apply global parameter to all same group...I have project parameter(diff. in each group) for assign global parameter.
Message 6 of 9
kadmonkee
each group would need its own global project parameter unfortunately, i have not found a better solution to that task
thank you
Message 7 of 9
pfiala-ebmprague.cz
please try and then write answer.
It's not possible add global parameter to elements in group....only if you are in edit mode...Then all same group have same value...
Need some group add global value and some without value.....simple question.
Also If I want different parameter in group it's not solution create more global parameter...because still you can't add global parameter to elements in group without use edit mode.
Message 8 of 9
kadmonkee
the answer is NO, it can't be done the way you want it to be done.
groups require uniformity, global parameters also require conformity, therefore you can't mix the 2 techniques to solve the issue
you can do 1 or the other within a project so some planning is in order.
I know its not the answer you want it is a limitation of REVIT
thank you
Message 9 of 9
Why can't you edit group?
