Assembly window not straight when wall grid not vertical or horizol.
nguyenquangchung288
nguyenquangchung288
Hi every one.
i create assembly window for callout detail them. But a have troubles with window or door...when the wall grid oblique direction.  please See attached photo
Help me. Thanks all.
L.Maas
When creating assemblies at odd angels you need to check the origin point of the assembly.
Edit the assembly and look for the origin point (sometimes bit tricky to find).
The green arrow is the direction in from which the view is build and is used as the front view of the assembly.
You can use the rotate tool to rotate it in the proper direction
Louis
Please mention Revit version, especially when uploading Revit files.
nguyenquangchung288
Thanks you. I make it like you guide. However, i feel so hard when rotate it angle parallel with wall.
i try Dim angle before rotate, but Not exactly accurate. How can you did it?
bin
Drag it(Blue dot) onto your window or wall, then rotate.
nguyenquangchung288
:))) thank you. it's so simply.
