Assembly Code: Masterformat vs Uniformat
studioZEUUW
Message 1 of 12
studioZEUUW
Our project currently uses Uniformat assembly code:
We want to switch to Masterformat for spec writing purposes.
We don't understand what will happen to the project once we upload a new assembly code file. The Uniformat system classifies entire assemblies but Masterformat classifies individual assembly parts (i.e. metal studs, gypsum wall board, etc).
Would a wall that has multiple parts show multiple masterformat assembly codes? Is that something that is done?
Thanks for any help.
Replies (11)
Message 2 of 12
What do you mean by "switch" to Masterformat? You cannot. They are two entirely different formats. Assembly vs. Keynote.
Message 3 of 12
studioZEUUW
I understand that one can use the Autodesk Standardized Data Tool to assign Masterformat numbers to elements. I have managed to get this tool running on my build and have successfully assigned a class to an element.
But given that the element is a wall assembly with multiple components, how do I assign masterformat numbers to each component in the assembly?
Message 4 of 12
Message 5 of 12
studioZEUUW
How would I get the information I can tag on a plan to appear in a schedule?
below shows the (incorrect) single masterformat class assigned to the wall
Message 6 of 12
Post the RVT File here.
Message 7 of 12
studioZEUUW
Err.. I don't think I can distribute this model. But what I am trying to do is described in this post too:
https://forums.autodesk.com/t5/forums/replypage/board-id/133/message-id/391202
Generally I tend to think that I'm doing something the wrong way if revit doesn't allow it, which is why I'm not sure if what @jamal340 and I are asking makes sense.
Message 8 of 12
studioZEUUW
I can mock up what I am trying to produce for the project. But this uses a "dumb" masterformat text parameter that I retype. Is it possible to bring native masterformat number parameter to parts?
Message 9 of 12
If you want to keynote individual components then use material keynote or create parts.
Message 10 of 12
studioZEUUW
Ok nixing the scheduling idea..
How would I go about adding a new keynote to the Masterformat keynote file downloaded by the tool?
Message 11 of 12
How is that a solution? Serious question.
Message 12 of 12
You need to edit the source file and add value to the description column.
