Assemblies Code
1 REPLY 1
nichlas.aa.holm
168 Views, 1 Reply
Assemblies Code
Hey.
I need some help too understand assembly code. I know that it's basic the same as keynotes, byt how can i make af assembly code file for myself?
The reason i want too make a assembly, is because of the possibility to make groups. I don't think keynotes can do that.
Regards
Nichlas
1 REPLY 1
cbcarch
in reply to: nichlas.aa.holm
I think you might be confusing some Revit terms here:
-"Assembly Code" is a system for defining a Family with a certain product--like a specification system.
See this: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
-An "Assembly" in Revit is similar to a Group--with different uses such as creating sheets and schedules for items to be fabricated.
See this: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
