Assebly code settings: not in library locations
XXalessio.amodioXX
XXalessio.amodioXX
Hi All,
I am trying to load assembly code, but this window pop up.
Any ideas?
ralphdenhaan
The file is probably not available in the default installation folder. Assembly Code
At Library Locations - finds the assembly code file where the stand-alone installation or network deployment specified
So change it to Absolute or Relative for example. I attached the default Assembly code file for you. You can also place it inside the installation folder and use the At library locations again.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
XXalessio.amodioXX
Many thanks for your reply.
I am currently looking for a UniFormat Classification with this type of structure.
E.g. A2010.10 - Subgrade Enclosure Wall Construction.
Any Idea?
ralphdenhaan
That looks like the one I attached for you to download in my post above.
XXalessio.amodioXX
Thanks for your reply.
I am looking for UniFormat2010Classification.
Something like this.
ralphdenhaan
See attachment;).
XXalessio.amodioXX
Exactly what I was looking for.
