Assebly code settings: not in library locations
XXalessio.amodioXX
937件の閲覧回数
6件の返信
メッセージ1/7
XXalessio.amodioXX
Hi All,
I am trying to load assembly code, but this window pop up.
Any ideas?
0 件のいいね
解決済み
938件の閲覧回数
6件の返信
返信 (6)
メッセージ2/7
ralphdenhaan
The file is probably not available in the default installation folder. Assembly Code
At Library Locations - finds the assembly code file where the stand-alone installation or network deployment specified
So change it to Absolute or Relative for example. I attached the default Assembly code file for you. You can also place it inside the installation folder and use the At library locations again.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
0 件のいいね
メッセージ3/7
XXalessio.amodioXX
Many thanks for your reply.
I am currently looking for a UniFormat Classification with this type of structure.
E.g. A2010.10 - Subgrade Enclosure Wall Construction.
Any Idea?
0 件のいいね
メッセージ4/7
ralphdenhaan
That looks like the one I attached for you to download in my post above.
0 件のいいね
メッセージ5/7
XXalessio.amodioXX
Thanks for your reply.
I am looking for UniFormat2010Classification.
Something like this.
0 件のいいね
メッセージ6/7
ralphdenhaan
解決済み
See attachment;).
0 件のいいね
メッセージ7/7
XXalessio.amodioXX
Exactly what I was looking for.
0 件のいいね
