Arrowhead of Stair path partially hidden hidden
Jaouher_Talbi_as272
Jaouher_Talbi_as272
Hello, i have a problem with the Arrowhead of the stair path, it's partially hidden by the last cut step (like shown in the picture) i played a little with the VV.
The only thing that seems works is if i put the transparency of the stairs at 100%.
jay_colc
Try increasing "Distance to Cut Mark" does this have an any impact?
Tab Select the Arrow > Type Properties
Jay Colcombe
Autodesk Certified Instructor
Jaouher_Talbi_as272
Thanks for the reply,
It seems to not want to put the arrow at the same level as the line of the step :
jay_colc
Sometimes moving it back from the Cut Line may get around some obscurity tolerances.
The only other suggestion are;
Changing the View Range slightly
or
Create a plan region (View>Plan View> Plan Region) on the stair, go to View Range in Properties (of the plan region) and adjust its Cut Plane to around 1000mm (rather than 1200mm like default).
Jay Colcombe
Jaouher_Talbi_as272
I found the solution,
Actually someone created the stairs manually with the landing as a step and not as a Landing. That caused a problem for the path to find the right height and it was constantly going inside the stairs :
