Arrow in the centered in the family, but not in the project when family inserted
Darwin33
Darwin33
I have a problem with this family.
The arrow of the door is centered in the family, but when i inserted in the project is not centered anymore.
Regards
I don't see an arrow in this family. Got a screenshot that shows what you are talking about?
Are you referring to the Room Calculation Point arrows. Why don't you make the Origin RP stationary and fixed, and widen your Door from this Origin outwards - equally in both directions?   Then the Room Calculation Point will always be at the center of the Door.
Did you lock the arrow family to a center ref plane?
Darwin33
Yes I did, the problem is that when flexing the door, one of the jambs is fixed and not flexed. Only flex the other jamb to get the right dimensions. So that is why the center line is never centered, bcz only flex one side. The Revit saids there is an error but can not find it with the provided code.
