Array with changing size in a Revit family
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to create an array based family in Revit as shown in the attached image. The sizes vary progressively and can be related with a simple formula, for e.g. side of square 2 = 2 x side of square 1 and so on.
Basically the reason for wanting to use the Array command is because the number of objects is to be kept as a variable. As an alternative what I'm doing is creating the maximum number of objects possible and giving them a visibility parameter according to the number entered by the user. But this may not always be the case that I know the maximum number possible. It needs to be a variable.
TL;DR: A linear array whose parameters change progressively is what I want.
Is this possible in Revit?
