array this in generic model line based
Message 1 of 9
hi
i try so hard to array this in generic model line based but still can't
anyone can help ?
Replies (8)
Message 2 of 9
post what you've got and we'll fix 'er up for you.
Message 3 of 9
this is what i got... i have tried to array this partition but didnt work...
when i give more length the partition didnt array with the same space
thank u
Message 4 of 9
Is this what you want?
Message 5 of 9
Dude? Any response? I'm waiting on pins and needles here.  It's uncomfortable.  😉
Message 6 of 9
that works bro... thanks a lot
Message 7 of 9
Hai Can you share any video How you make it I have tried but it failed
Message 8 of 9
RDAOU
@Anonymous
Its good that you want to learn and not just use what is posted, so here is a video for you:
  1. The profile Family does not need to be Work Plane-Based
  2. You do not need to host the profile on the Ref. Line as mentioned in the previous post
  3. Note: Locking to Start and End of the array + Using Append to middle will not generate equal gaps between the arrayed profile. Should you need the Profiles to be arrayed equally, the array will need to be set up differently.
Message 9 of 9
Thx a lot
