array on both directions in family
Hi all, i'm trying to figure out how to create an array that works on both directions.
I've set the parameter for the number of element for both arrays, but i need also to link them, so it gives a result as in the attached file. (sorry i really don't know how to explain my task)
L.Maas
Hereunder an example of a 2D array. Attached the xample (Revit 2016)
Revit's array function is only one dimensional. So the trick is that you create a second array to array the first array.
To do this in a single family is often quite difficult. To get better control of all the constraints what I often do is. Create a family. In that family I array the objects (often a nested family) in one ditection. This array family I nest in a new family (host). In that host I array the nested family in the other direction. I pass through the relevant parameters so that in my host I can control both arrays.
In my attached example:
1-Family with objects (a simple box) to be arrayed
2-A family with the nested 'box' family, arrayed in the X direction.
3-A family with the nested Array-X family, arrayed in the Y direction
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you very much!
