ARRAY DIAGNOALLY
ARRAY DIAGNOALLY
ARRAY DIAGNOALLY
 I WANT TO ARRAY THE CIRCLES IN A DIAGONAL WAY ALONG A DIAGNOL WALL AS YOU SEE IN THE IMAGE. UNFORTUNATELY I CAN'T FIND A WAY TO DO THIS. DOES ANYONE HAVE ANY IDEA HOW DIAGONAL ARRAY IS DONE ?
BIM.Consultant
Are these 2D circles / openings or solid geometry? You might need to uncheck constrain while using array.
However, I would suggest creating a line based family for these circles.
ennujozlagam
@Anonymous hello mate, here are a screencast video for  diagonal array. thanks
FGPerraudin
Hi Puya,
Yes, just untick the constrain box in the option ribbon once the array tool is activated.
It wuill solve your problem.
Francois-Gabriel Perraudin
BIM management and coaching
they are solid contigous piles on retaining wall . They are geometry but I drew them as two dim objects to make it easier and the file size smaller. Thanks for your reply as it taught me a new aspect to rveit.
A line based family as suggested should work regardless of 2D linework or 3D geometry.
