I've recently joined a project that has accumulated a fair number of warnings that I want to clean up.
There are numerous "Area separation line is slightly off axis" warnings, which are an easy fix, however there are a few that I cannot remedy. The Select by ID feature will select the line, but I cannot find them on any area plan, or adjust the line in 3D.
Is there a way of identifying the view in which these lines are present?
Or is there a better fix?
Thanks in advanced.
Solved by ToanDN. Go to Solution.
Can't you drill down into the error dialog to "Show"? Or, select the element by ID and use the "Find Referring View" function.
Hi
just for an Example.. When we create a Room, and delete them, they are still available
in the schedule... and it mentions ( not placed )
Similar to that, Area lines, once placed on Area Plan.. once the Area plan are deleted... they
are still there, just that not visible in any of the plans..
so solution is to Recreate Area Plan for that associated Levels, and those Area lines will reappear..
uploading a screencast to show that area separation line behaviour as well..
Cheers..
Thanks for all the suggestions and advice.
This was precisely the issue, areas on unused plans.
I am creating area plans of each area type on each level and going from there.
Thanks again.
