Area Schedule
Area Schedule
Area Schedule
I need to create this type of schedule but i dont know exactly how can i set up the parameter of the area family to be able to have "Area types". I going to add some pictures of what i need and see if someone can help me. Thanks
this is how should look when i select a area in my area planthis is how should look when i select a area in my area planThis is how should look my area scheduleThis is how should look my area schedule
Current area parameterCurrent area parametercurrent schedulecurrent schedule
To transfer subtotals from rows to columns you need to create conditional formula for each area type.  See the similar thread:  https://forums.autodesk.com/t5/revit-architecture-forum/areaschedule-subtotals/m-p/8565462#M227891
Of not clear, share your file.
Thank  Toand, but my problem is create first the different types of area to be able to see in my schedule as the picture that I attached. Residential area, Commercial etc.
Area types are hard-coded.  But you need not to rely on it, just use any other parameter such as Name or Comments, to give them different 'types'.
I already tried that but the only thing that happens is that a new column appears with the name of the area.. not with the actual area number.this is what i get if i do that. Just another column with the area name .this is what i get if i do that. Just another column with the area name .this is what i need a column called commercial area or residential and below the area of that space !this is what i need a column called commercial area or residential and below the area of that space !
for that reason i need to set up properly the area family with the proper parameter.
I think you do need to to look at the reference thread I provided earlier more thoroughly .  It is not just similar, but exactly the question.  Again, feel free to hare your file here.
Here is an example file.  A screencast will be up later.
https://knowledge.autodesk.com/community/screencast/0378dd60-cade-49d3-8f43-4f5df652021b
Screencast will be displayed here after you click Post.
