Architecural presentation drawings
nichlas.aa.holm
Message 1 of 10
nichlas.aa.holm
Hello all
Is it possible to make drawings like the one's below in revit??
I am especially interested in knowing if I can make terrain and hedges with that color combinations??
If so, how do i do it?? 🙂
Replies (9)
Message 2 of 10
Sure you can do that in Revit.  Where are you struggling exactly?
...an Image Underlay would be one approach (of many).  You could do the artsy farty stuff in another software and bring it into Revit as an Image.
Message 3 of 10
nichlas.aa.holm
My struggle is with the terrain and hedges. To make an underlaying image, could be done, i would much rather have a solution there could be done in revit. 🙂
Message 4 of 10
I just gave a solution on how you could do something artsy farty like that in Revit - a BIM Software.  But you can certainly do all that artsy farty stuff directly in Revit - a BIM Software.   Hard to advise you on a creative process though - especially not knowing your skill level.   I would suggest researching for approaches using Google.
Look at what I found by inputting the keywords "Revit" and "Watercolor". That's what I'm seeing in your screenshot. A watercolor effect.
 https://www.youtube.com/watch?v=82HW0OlZCcA
Message 5 of 10
ryley.g.h
Create a custom material and add it to a new floor type. Use the floor type to create the water colour site effect.
After that, do the 2 view over top of one another on a sheet trick. One view will be set to rendered, and only show your grass/trees/ect. The other will only be your plan elements. Drag the rendered view on first, then the plan view, and line them up and bobs your uncle!
Message 6 of 10
nichlas.aa.holm
Do you think you can show me how to create a custom materiel with that effect?? I can't figure it out. 🙂
Message 7 of 10
nichlas.aa.holm
Thanks for your reply, but that solution depends on photoshop, and i was hoping to find a solution in revit. 🙂
Message 8 of 10
Get a high quality image from the internet and set the texture size as big as your lot or even bigger so that the material does not need to tile.
Message 9 of 10
nichlas.aa.holm
Thanks i'll try. 🙂
Message 10 of 10
Didn't you forget to thank someone else here?
