Architecture_Area in Grey cannot select
Message 1 of 10
Hi. I want to make an area of a room but connot pick up Architecture_Are as this is in grey and cannot select it... don't know why?
Replies (9)
Message 2 of 10
Why don't you use Room instead?
To use Area you need to create Area plans. They serve other purposes such as Gross Building Area, Rentable/Usable Area, etc...
Message 3 of 10
Ok but room doesnt calculate areas?
Message 4 of 10
Is it diificult to create area plans?
Message 5 of 10
Once I created a Room
There is a double anoying "Not Enclosed" bellow
How can I get rid of these?
Message 6 of 10
Or even better how do I edit the boundaries of the room to adjust them??
Message 7 of 10
Yes. They do.
Message 8 of 10
No. But you need to manually draw Area boundaries to calculate Areas.
Message 9 of 10
Do you have walls around the Room?
Message 10 of 10
Draw walls, or Room boundaries around your Room and adjust them.
