Architectural Revit 2018 file always Fatal Error Clash
diacreek
diacreek
It can open,
When go to view, it goes fatal error terminated. Have to roll back to 2D drafting.
Project starts up, needs it fixed asap.
The Revit Architectural file is over 200MB, phase out to upload option.
Open the Project with AUDIT checked.  Inspect and resolve Warnings.
...Open and inspect your last Backup.
L.Maas
You can always use a service like wetransfer and then post the link.
For the moment only work on a copy of your project and keep the backup files save.
You could try to delete the mentioned problematic view, see if that solves the issue.
Also loading with audit acitvated might give some information.
Further check the journal file and see if there is an error mentioned.
Louis
Please mention Revit version, especially when uploading Revit files.
diacreek
When using Audit to investigate, it comes up missing many elements, and it cannot be opened.
As attached snapshot, any idea to fix it.
No way to fix it, but you may have a Backup that was working before Revit choked.
