Arch length dimension for intersection of curved wall and straight wall by wall core not wall centerline
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I'm having an interesting issue. I have a curved wall intersecting with joined straight walls. I want to dimension the arc length on the curved wall, but to the center of core and not the wall center line, but the center of cores do not extend and intersect between the walls (wall center lines in blue, center of cores in green):
I have found a gross work around with disallowing both wall joins, extending the walls to the finish face of each, dimensioning the arc length, and then allowing the joins for the curved wall (if you allow the straight walls it breaks the dimension because the center of core line moves back to it's original spot):
However, I worry that something may break in the future if any walls move slightly and really don't want my team to have to go through the entire project modifying every single wall join. Also, I would prefer if we didn't need to draw detail lines on all wall joins to make this work as a different work around. Is there a different method that I am missing?
Any ideas would be helpful!
