I have a title block I have been using successfully in Autocad that has been created around 36"x24" (arch D).
I have brought it into Revit, but when I export the PDF the size gets reduced to 32"x22" on the 36"x24" background. How can I truly print the bigger size?
Also, take the time to make a proper title block in Revit. It'll save you tons of time in the long run and prevent a lot of opportunities for error.
M settings are a bit different, but work for me.
You should create a Revit titleblock. That way you take advantage of all the smartness in parameters. Like having the correct name, print date and so on done automagically.
