Apropriate Revit Keynote for Shiplap Wood for Exterior Walls
kurta.pollock
kurta.pollock
What's an apropriate Revit keynote for shiplap or T&G wood (non-plywood) finishes for exterior walls? I can't seem to find a suitable keyvaule that fits the description.
06 42 00—Wood Paneling
07 46 23—Wood Siding
or not.  Why don't you look at the manufacturer's specs?
https://www.arcat.com/sdspecs/htm04/07_46_23tfp.htm
kurta.pollock
I'm using the Imperial 2010.txt values, there is no 06 42 00—Wood Paneling value. Is there a repository where the information can be located so i can update the list of values?
Use Google. Search keywords = Master Format, CSI.  Or go to the manufacturer's website.   Then edit the Keynote txt file and enter the information.
Video: Edit a Keynote Text File | Revit 2019 | Autodesk Knowledge Network
kurta.pollock
Thanks, you were a great help.
