Anyway shortcut to delete open tabs?
remberto.mendoza
remberto.mendoza
At times I have so many tabs opened. Anyway to use a hotkey to close tabs since Ctrl+W just closes completely the project.
RDAOU
@remberto.mendoza
You can set one...
GO to Ribbon >> View >> User Interface >> Keyboard Shortcuts and assign the shortcut key(s)...I use ci
OR alternatively if you cant make up ur mind on a shortcut key simply use the button on the Ribbon
OR you could also customize the quick access tool bar and add a shortcut
.. or use this button
remberto.mendoza
That work perfectly! thanks!
By the way is there another shortcut to close some inactive views one by one not all at once??
RDAOU
Wouldn"t the X be faster to close the Active view(s) one after the other?
arq_42
This is a bit of an old thread, but in case anyone ends up here, Ctrl+F4 is what you're looking for.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
