Any flexible way to deal with room boundaries?
526996629
526996629
Any way to set the room boundaries at wall centers for interior walls and at wall finish for exterior walls? (I hope there is a way without using area plans.)
Simon_Weel
Rooms and Area plans are two different things, but anyway - it's a whole-sale operation. There's no different settings for interior / exterior walls. There are some Dynamo script dealing with Room boundaries.
Mark_Engwirda
@526996629 A room boundary is always finished within the inside face of the walls, eg what you would expect in everyday life.
If you wanted to finish a room boundary as you have shown;
  • Go to the properties browser and uncheck the room bounding option for your walls.
  • Go to the line separator tool and create the line on the outside face  or centreline of your walls
Jus to be clear, I would not recommend this practice, especially in any project that's not a small project.
handjonathan
Hi @526996629
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Simon_Weel @Mark_Engwirda  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
